3.5 J35A4 Honda V6 Custom Build For Sale
Our Honda is for sale! The absolute sweetest 3.5 on the planet, with lots of power and torque. Custom built by Tim Beadle of Arizona Performance Imports.
This is a newly built engine, with 2 hours run time on a test stand to seat the rings.
We advised Tim Beadle (API) that our goal was 325 hp, and 290 to 300 pound feet of torque. Here is what Tim did for us:
Polish is standard...we chose to powder-coat the valve covers in jet black, painted the block in New Ford Gray.
All internal parts are new, Acura / Honda factory OEM.
J35A4 block
Cylinder heads fully ported and polished
Match port intake runners and manifold
Form tool valve job
Type "S" cam shaft, higher lift and duration
Intake manifold lowered
Crankshaft and rods micro-polished
11 to 1 compression ratio Acura Pistons
Fully balanced
Almost $8,000 spent on this custom build. Will sacrifice for $5,900. The engine is at the Titan factory now, so you would need to have it shipped to your location.
J35A4 block
Form tool valve job
Fully balanced
