Hello I have a 93 Del sol SI and I want to get a OBD1 B16A to put in it. Can anyone tell me if Jazzproparts is relieble with there engines? If not were else can I get one with what I need for the swap. Thank you.
hmotors engines come with everything...i have never got an incomplete motor and/or swap from them...they are #1 as far as honda engines go and give steve a call, he sometimes ships for free
Did your engine come with shift linkage power steering pump an a/c compressor or do I need it to go from a delsol SI {d16z6} to Vtec {B16a}. I know the shift linkage is different.
tell him you need the sol vtec linkage. he will give it to you if he has it.
pwr sterring pump comes with it- but you don't need it. all you need is the brackets.
