Jb Weld
Ractive78
Would jb weld be safe to use on my down pipe? Can it take that much heat?
Thanks
ive used it on my radiator and it stayed on for like 2 months before it came off by itself..but i think it came off because of the hot fluid trying to leak out. guess it should work ok on a downpipe, but i would just get a propane torch and some solder for $20 and weld it.
solder melts at about 350F to 700F. What you'd need to do is braze the joint or weld.
umm does that really work? that isnt TRUE welding per se.....
