Jbm odb2 B18c swap in 96 ex help
Discussion in 'HYBRID -> EG-EK / DC' started by dans, Aug 15, 2010.
  1. dans
    dans New Member
    Jbm odb2 B18c swap going into a 96 ex coupe. I want to run the USDM obd2 ecu so I can pass inspection in Texas .I'm not sure yet if they plug into the computer here in Dallas even if the engine light if off. JDM obd2 ecu wont communicate with the scanner. So my question is what cels will the USDM ecu throw that I will have to fix .I know about the Vtec pressure switch bypass & ckf bypass trick. I guess my ex o2 censors are ok ? What about Evap purge cel ? I will pin iab at a26 and ground other wire. Am I forgetting any other wiring for obd2 B18c with USDM ecu on Obd2 ex coupe ? Thanks, Dan
  2. dans
    dans New Member
    Bump!! Anyone please.Nobody got obd2a jdm b18c on usdm obd2a ecu?:)
  3. dateg513
    dateg513 New Member
    cincinnati
    Try and stay with a 96-98 ecu i think . 99 and up you need a obd2b to obd2a jumper harness.
  4. hatchbuild10
    hatchbuild10 New Member
    Cali
    I recently put a b18c1 into a 96 civic ex and all i did was use an obd2 from an integra ran fine till i replaced the intake manifold and injectors now it runs funny. getting tuned this weekend though. i hope this helped.
