dohcvtec_accord, myself, and another friend did the exact same swap you are talking about in a weekend in our garage. Mechanically the install is cake. We had some troubles with the wiring because noone would give us a straight answer. If memory serves the only wiring change that is needed is to swap the wires for pins A6 and A11 on the ECU. You an EX so you have all the VTEC wiring.
Chris, did we have to run a wire for a knock sensor?
