JDM B16 LSD cable trans Q?
Ragnarok
Ok, I've been searching, but not finding any info, so here's my situation: I have a B18A in my EG sedan. Had an LS trans, but needed to replace it, so I lucked out and got a JDM B16 LSD trans. The issue is, apparently now the hydro-to-cable trans conversion kit I was using doesn't line up correctly and won't work. Is there a kit for this specific trans? Am I missing something? :confused: Any info/advice would be greatly appreciated. Thanks for reading.
Get the HAsport hydro to cable conversion kit. It's a direct bolt up. Very simple and will make life easy for you:cool:
More info: I've had the b18a w/the ls trans (with conversion kit) in my civic for about 2 years now, worked fine. swap in the ys1 trans, using the same parts from that conversion kit, and suddenly nothing lines up. can't even install the slave cylinder...
