Red94CivicDX
I put my JDM b16 sir-II swap in my 00 SI. I am using a JDM P30 ECU with a OBD2b to OBD1 conversion harness from JDMShit.com. I am getting a code 10 for IAT Sensor. I don't have another plug from the stock SI wire harness to fit my IAT Sensor on my intake. I checked the ecu error codes on Hondaswap. Here is what code 10 says:
10- Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98
IAT Sensor (Intake Air Temperature)
defective circuit or unplugged / defective sensor
It doesn't say anything about 1999 or 2000. Do i have to wire this from my ecu to the IAT? I have read several articles on the OBD1 into an OBD2b car and haven't seen anything on this. If any of you have done this swap please let me know what to do. The car is running ok, just stumbles after it warms up and I think it is dumping fuel because it is running in loop mode with the CEL on.
