jdm b16 water pump?
Discussion in 'General Tech and Maintenance' started by Yurik, Aug 10, 2007.
  1. Yurik
    Yurik New Member
    ive got a jdm b16, obd0, pr3, curious as to what i do for a water pump? ive tried the 97 del sol dohc vtec and the 99 civic si dohc vtec, and neither will work...any ideas? :confused:
  2. formby
    formby learning in progress
    all oilpump/water pumps on 96-01 b series engines are the same
  3. Yurik
    Yurik New Member
    any idea what i could try then?
  4. formby
    it has to work... a b16 in any OBD [0,1,2a,2b] the castings are the same....
    someone correct me if i'm wrong
  5. keithss
    keithss New Member
    okay first of all .. ATTENTION!! all Honda enthusiast honda civic si b16 motor are not ALL interchangeable with jdm b16a parts i work at auto zone I did this research for a long time water pump from a si doesnt match up with a 0bd0 b16a. People use to say oh yeah any of the Si or del sol with fit. This isnt true maybe some parts fit. but please dont tell other people that everything fits from 97-01 b16 because its not true. okay next try a 94 del sol because usa started late making these b16s so youll never really find a real ob0 b16a parts for example good luck finding a distributor cap at a autoparts store unless you shop online. so if youll hate me peoples im sorry but im right. Everything
    I said is fact so spread the word. cya'll
  6. Magana559
    Magana559 The Warden
    fresno Ca
    No Mr. autozone, they WILL fit. as long as its a Civic SI with a B16 it will fit. even a GSR water pump will fit. dosent matter if its a OBD0 1 or 2a/b.
  7. Magana559
    fresno Ca
    oh fuck, this is 2 years old FML!
  8. keithss
    keithss New Member
    okay so i guess a GS R Obd2 distributor will fit my obd0 b16a.. good job! not. ya i know its 2 yrs old so what im bring it back. ya and also does a gs r timing belt work on a b16a too? guess what it doesn't! and before answer back to me do it and try it!! then you can talk trash ill be more than happy to listen. :)
  9. keithss
    keithss New Member
    ok i have a question now since we are back in and the original thread is not even looked at anymore. How would Gsr parts on a b16a motor benefit it. make it faster or is it so you can tell people you wish you had a gsr but instead you have a few gsr parts on it? Not trying to offend anyone but really whats the answer??
