JDM b16a obd1 into eg hatch no spark
Pyro
I recently swapped a JDM b16a obd1 engine into my eg hatch. The engine started and ran great but the fuel pump wasn't running so we had to run a wire directly to the battery. After turning it off and checking the fuel pump we tried to start the car again and it isn't getting any spark, there is power to the distributor but still not spark, I'm stumped
With this new wire change.....do you hear the main relay click and fuel pump prime for a moment when key goes to "on" position? (Car not started just "on" position)
If so.....do you smell gas on the spark plugs?
Any other wiring changes? Grounds maybe.
If you have power to the dizzy maybe you fried the ignitor. There is another one inside but for the life of me I can't remember what it is called atm. I've had the exact same thing happen a few times.
