JDM b16a obd1 into eg hatchback distributor doesn't have spark
Discussion in 'HYBRID -> EG-EK / DC' started by Pyro, Jul 20, 2014.
  1. Pyro
    Pyro New Member
    I recently swapped a JDM b16a obd1 engine into my eg hatch. The engine started and ran great but the fuel pump wasn't running so we had to run a wire directly to the battery. After turning it off and checking the fuel pump we tried to start the car again and it isn't getting any spark, there is power to the distributor but still not spark, I'm stumped
  2. Briansol
    is the check engine light on? what ecu are you using? what model trim is your eg?
  3. SwapShopRacing
    SwapShopRacing Member
    650n Barranca ave #a Covina, Ca 91723 (626) 261-4
    Sounds like a bad Igniter or Coil. If your Fuel Pump is not turning on then I would check your main relay first rather than just running it direct.
