Hey I need help on a swap you guys might know. Its a Civic EX getting a JDM B16A swap. My only problem is about the engine harness. I noticed that the D16Z6 motor has a MAP sensor on the throttle body and I also notice theres a EVAP purge solenoid. How would I get around this when the JDM B16A doesn't have a MAP sensor on the throttle body? Should I switch it with the D16Z6 throttle body? Also what to do about the EVAP purge solenoid? This is the only two problems that got me stumped.
