im puttin in a jdm b16a into my civic dx what all do i need, i already have a chipped p28 ecu to run any dohc vtec . what wiring harness do i use, any ideas
He's right, use your DX harness. Depending on your donor motors year of production you'll need to run 3 wires to make it work. If your motor is a '95 B16A, there is onlyone wire for VTEC. You should go to .: FF-SQUAD.COM [v.2] :. for the wire codes. It will show you how to pull harness pins and a pinout diagram.
use stock harness like they said above. since its 95, its still obd1 so you wont need a jumper harness. my motor is obd2 so i had to purchase a jumper harness to run the p72 ecu.
