JDM B16a1 full EF Swap Cheap and Clean
s240161
Member
EF B16 Swap plus extras
JDM b16, mounts, harness, chipped ecu, new oem headgasket, new oem timing belt, new oem waterpump, Underdrive harmonic dampener,Cable trans,new ACT street clutch disk,new OEM pressure plate and throwout bearing, new inegra clutch cable, new oem gaskets (intake , exhaust,, valve cover, ETC.) Intake and 2 exhaust manifolds(JDM with both o2 sensors and 99si), 8 injectors, 2 fuel rails, PRO valve adjustment, HASPORT? shift linkage,new distributor, probably some stuff I forgot.
ASking 1700
