JDM B20b 96-98 & 99-01 OBD2 Engines
Discussion in 'Parts: For Sale/Trade/Wanted' started by TorontoJdm, Jun 21, 2011.
  1. TorontoJdm
    TorontoJdm New Member
    TorontoJDM.com
    JDM HONDA B20B 99-01 OBD2 ENGINE ONLY
    ITEM LINK: http://www.torontojdm.com/cart.php?target=product&product_id=4626&category_id=101
    $699.99
    INCLUDES:
    ENGINE BLOCK
    HEAD
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    CRANKSHAFT PULLEY
    THROTTLE BODY
    INJECTORS
    FUEL RAIL
    VALVE COVER
    SPARK PLUG WIRES
    SPARK PLUGS
    OIL PAN
    OIL CAP
    DIP STICK
    1999 - 2001 SPECS
    • NON-VTEC
    • FOUND IN: USDM CRV AS A B20Z, CR-V AND HONDA ORTHIA AS A B20B
    • DISPLACEMENT: 1,973 CC (120.4 CU IN)
    • POWER: 146 HP (109 KW) @ 6200 RPM
    • TORQUE: 133 LB•FT (180 N•M) @ 4500 RPM
    • ROD LENGTH: 137 MM (5.4 IN)
    • COMPRESSION: 9.6:1
    • BORE: 84 MM (3.3 IN)
    • STROKE: 89 MM (3.5 IN)
    • REDLINE: 6700 RPM
    JDM HONDA B20B 96-98 OBD2 ENGINE ONLY
    ITEM LINK: http://www.torontojdm.com/cart.php?target=product&product_id=4520&category_id=101
    $499.99
    INCLUDES:
    ENGINE BLOCK
    HEAD
    INTAKE MANIFOLD
    EXHAUST MANIFOLD
    CRANKSHAFT PULLEY
    THROTTLE BODY
    INJECTORS
    FUEL RAIL
    VALVE COVER
    SPARK PLUG WIRES
    SPARK PLUGS
    OIL PAN
    OIL CAP
    DIP STICK
    1996-1998 SPECS
    • NON-VTEC
    • FOUND IN: USDM AND JDM HONDA CR-V, JDM ORTHIA, STEPWGN, S-MX
    • POWER: 126 HP (94 KW)) @ 5400 RPM
    • TORQUE: 133 FT•LBF (180 N•M) @ 4300 RPM
    • COMPRESSION: 8.8:1 OR 9.2:1
    • REDLINE: 6300 RPM
    *OTHER PARTS AVAILABLE FOR SEVERAL MAKES AND MODELS. FEEL FREE TO CONTACT US FOR PRICING FOR YOUR SPECIFIC NEEDS / VEHICLE
  2. TorontoJdm
    TorontoJDM.com
    Got a Budget?
    Want added Power?
    Desire Bseries?
    ...look no further
  3. TorontoJdm
    TorontoJDM.com
    in stock and ready for your build... Boost maybe?
  4. TorontoJdm
    TorontoJDM.com
    replace your blown b series block?
    boost project?
    budget build?
    ...contact for details.
  5. avenger97
    avenger97 New Member
    Do you have any obd2 p75 ecu (manual) by any chance..?
    Thanks
