jdm d15b crx si
Discussion in 'HYBRID -> ED-EF / DA' started by SlowCrxSi, Feb 11, 2009.
  1. SlowCrxSi
    SlowCrxSi New Member
    Nashville
    well i swapped the d15b in my rex andit idles at 3500rpm.im using an h22 tb and z6 fr.also im still runnin oem ecu...help needed,any suggestions
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    run the correct ecu and tb
  3. SlowCrxSi
    Nashville
    nope it was just a tb gasket
  4. AHHVTEC
    Alabama
    you still need the correct ecu for the motor to run right
  5. SlowCrxSi
    Nashville
    no it runs fine just no vtec
  6. AHHVTEC
    Alabama
    so you running at d15b vtec with a crx si ecu ? if so im guessing the motor is already messed up
  7. SlowCrxSi
    Nashville
    ok smart guy explain how
  8. AHHVTEC
    Alabama
    its a vtec motor if you take it past where the vtec should cut on at your risking it. why not just buy a 80 dollar p28 and have vtec and be done with it
  9. SlowCrxSi
    Nashville
    i dont take it past 3500,im not a noob i do know these things.and i cant just buy a p28 b/c then i also have to buy a jumper harness.i have $520 in this thing and thats including the $120 it took to tow it.in 2 weeks im getting the apexi neo so i can control vtec and fuel enrichment,b/c i could just hook vtec up 2 a switch but it will run lean as hell.b/c the fuel maps in the d16a6 ecu and d15b ecu are diffent.i was just asking for advice why my car WAS idling at 3500 not for you to tell me my car isnt going to run right.the h22 tb doesnt make it run any different just more air,but it really wont help too much till i port match the im.so before you start "helping" ppl with there car maybe you should do some research and experiments on what will work and what wont
  10. AHHVTEC
    Alabama
    lmao in case you cant read i was trying to help you in my first post either one of those things i said could cause that. and yes you are a noob your doing everything half assed and your wondering why stuff dont run right.theres nothing you can tell me that i dont already know.i bet thats one real screamer of a motor you have there with it not going past 3500 rpm and all
  11. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    check for vacuum leaks instead of posting, also make sure the injectors are correct. OBD1 civc injectors do not require the resistor that is in the Si .
  12. SlowCrxSi
    Nashville
    if you read correctly i said i dont take it past that,i didnt say it wouldnt.....thanx for the help z6 but i already fixed it.
  13. SlowCrxSi
    Nashville
    and mr vtec,you did start out givin ideas,i appreciate that.but when i told you i fixed it you was like"its still not gonna run right"and it runs fine.kindA sluggish b/c i had to retard the ignition timmin b/c i used the a6 dizzy.i just didnt like you tellin me that,so if you wanna keep arguin over the net like little kids,fine.idc
  14. AHHVTEC
    Alabama
    just trying to save you further headache down the road. and if its only going to 3500 rpm would you call that running right.
  15. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    lmao
  16. wifeCRVmeEF
    wifeCRVmeEF New Member
    is the D15B motor supposed to be a high revving SOHC??? 3500rpm?? i would change the ECU, but thats me:p
  17. SlowCrxSi
    Nashville
    ok lemme spell this out for those of you who didnt pay atten. in english class.I DO NOT TAKE IT PAST 3500, IT WILL GO PAST THAT!as i had said before,and for record im just satisfied with the car.why would i use vtec if the clutch is going to slip when i shift at high rpm?you wouldnt,you would baby it till you got the money to get it right..hmm,maybe thats what im doin?
  18. SlowCrxSi
    Nashville
    any way,i have a problem that i kinda half assed.im using the a6 dizzy on the d15b,and lets just say it dont quite fit,it works but i have oil seeping out the bottom were the dizzy meets the head.if i use a z6 dizzy the plugs to the harness are diff. right?so should i just get wiring diagrams and splice it or what?btw if you have anything negitive to say,go whore someone else's thread.
  19. Z6CRX
    Pittsburgh, PA
    may want to check out the clutch if its slipping then. A stock sohc vtec does not have the power to slip a good clutch, it is caused by adjustment or wear.
    Clutch adjustment could fix that theres an adjuster on the transmission if your running a cable transmission.
    Also using the Z6 distributor would require changing it to OBD1, which I would highly recommend. If not you will have to swap the internals of the distributor since the distributor internals are not compatible with OBD0.
    Overall OBD1 gives you more tuning solutions and lets you run what the engine was original setup to run under.
  20. SlowCrxSi
    Nashville
    yea the clutch is just worn,its the clutch off the a6,i used a6 clutch,pressure plate and flywheel.the a6 pressure plate wouldn fit on the d15 flywheel.i knew the clutch needed replacing i just dont have the money yet.btw if i switch everything over to obd-1 what would i swap.i know the dizzy,ecu(i would need a jumper harness).but would i just need and under hood harness from an ex or si eg and it plug right in?
