Hi, new here and have a few quick questions.
Just picked up a clean 94 DX coupe with a JDM D15B swap.
D15B is etched in the block, and it has the two solenoids for the 3 stage VTEC, but the casting on the head reads "P2J-6" which leads me to believe its a D16Y8 (ex) head. What would the casting read if it was an actual JDM cylinder head, if there is a difference between mine and the original, and will it run right?
I am trying to run this engine with a P28 ECU and P08 basemap, but am unsure about this cylinder head on the D15B block and unsure about which harness to use.
Will a D16Z6 harness with custom wiring for the 3 stage work?
Thanks
Dylan
Thanks
Dylan
