Jdm d15b vtec in si crx question
Discussion in 'Civic and CRX - EF' started by DB8401, Jul 9, 2008.
  1. DB8401
    DB8401 New Member
    Hey guys this is going to be one of my first obd1 sohc vtec swaps into civic ef's.
    Its not a DX or STD, Its A 89 CRX SI So No Need For Me To Do DPFI to MPFI
    questions are:
    1. Am i going to be using all 3 of the 92-95 engine motor mounts
    2 Which wire harness do i use, (pretty sure the si ef one)
    3. Do i need to use all sensors off of d16a6 on to jdm d15b
    and yes i know i need the rywire obd- to 0bd1 for my p28
    and yes i know i have to rewire my d15 dizzy to obd0 plugs
    Someone get back at this with me thanks.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    use your stock harness then just all the extra wires you dont have, you will use all of the crx stock mounts but one you need to swap out the driver side mount.
  3. DB8401
    DB8401 New Member
    So your saying, i could use the 92-95 motor mounts but i have to use the crx driver side mount correct..?
    So the crx si harness wire will plug up on the jdm d15b correct..?
  4. AHHVTEC
    Alabama
  5. DB8401
    DB8401 New Member
    alright ill do as u say but if anything ill post up.
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    1.) No! Use all your stock mounts(EF).
    2.) Yes, the Si one, You'll just need to add the VTEC wires.
    3.) No. The sensor are pretty much the same. The D15B just lacks a purge solenoid valve.
  7. AHHVTEC
    Alabama
    but he will need to change the driver side mount for the new motor one
  8. K2e2vin
    Raleigh, NC
    Yes, just swap in the mount off the old engine(the part that connects to the engine and the part with the bushing)..
  9. DB8401
    DB8401 New Member
    i didnt get that. please explain please.
  10. DB8401
    DB8401 New Member
    anything else i need to know..?
