JDM ecu vs USDM ecu
Discussion in 'ECU's, Electronics, and Tuning' started by projectxspeed, Jun 21, 2004.
  1. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    What is the difference between the two? Specificial the p30 and p72.
  2. projectxspeed
    New Hampshire
    I know the wiring in the engine harness is backwards, but with a jdm ecu plug in and work for a usdm harness and engine?
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    JDM Ecu's will have a speed limiter on them at around 115ish mph. Both will plug into your harness no problem.
  4. projectxspeed
    New Hampshire
    Awesome that what I thought I just wanted someone else to confirm it for me. As for the speed governor that what uberdata is for :)
  5. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
