EdrikLongtail
For a 89-91 b16 sirI compelet change over, For the wiring can i use the usdm harness with jdm plugs or can i just switch the hole wiring harness over and try to make everything fit?.
Originally posted by E_SolSi@May 27 2003, 06:27 PM
use the USDM harness swap any plugs that dont work with the JDM harness
for any wires that need to be lengthened just steal them from the JDM harness
Originally posted by vtecaybek@Jun 15 2003, 01:02 AM
i think USDM and JDM harness will same. Only USDM ecu s has more some sensor so usdm haness has some more cable and the jdm ecu side of this extra cables is empty
Any ideas ?
Originally posted by civic_01@Jun 15 2003, 07:47 PM
hello my name is angel, I barely bought a b16a but im having problems puttting the ecu into a 91 civic std
