JDM GSR Swap B16 tranny ls 5th Skunk 2 goods NICE swap!!
dornon13
willing to sell the tranny now 600 takes it
also axels, shift linkage , and mounts are up for grabs
forgot to add zip code its Tullahoma, TN 37388
Looking for
$2700 with hasport mounts
$2500 without
add 400 for skunk2 pro1 cams subtract 100 if you dont want the GSR cams
JDM Gsr-- 70k miles
hasport mounts
skunk intake manifold
skunk retainers
skunk valve springs
skunk pro cam gears
98 type r header
hondata intake manifold gasket
P28 ecu chipped from phearable.net
B16 tranny w/50k miles (with LS 5th gear for highway driving new syncro hub set done right! like 100mi on that)
exedy stage 1 clutch
exedy 9lb. fly wheel
98 itr gold shift linkage and shifter
the cams i am selling seperate for 400 i dont want to seperate the header or manifold but the manifold is the old sk2 style
not parting out unless someone wants just the engine for 1800 which is about the same as teh hmotorsonline price i will not part the swap unless someone buys the engine first.
huh? this isnt a part out thread...if you are looking for compatibility the dizzy is obd1 and the shift linkage is out of an integra type r
how much for these:
B16 tranny
