jdm gsr swapped into 5th gen hatch
Discussion in 'HYBRID -> EG-EK / DC' started by Eg6nRpS13, Sep 21, 2005.
  1. Eg6nRpS13
    Eg6nRpS13 Junior Member
    I just finished my jdm gsr swap into my 95 civic cx, got rid off all the check engine codes, but I ran into a problem , I just received my apex n1 exhaust today and everything is fine but I found out the my usdm type r catalytic converter does not fit. The bolt pattern is not perfect and bolts will not go in correctly. Which catalytic converter do you guys suggest I can buy for now that can fit without cutting and welding. I need this up and running asap, need to go register and inspect the car, and heading off to colorado on monday. Anyhelp would do . THanks
  2. pissedoffsol
    allb-series cats have the same bolt pattern... its the lengths that are different.
    its probably how you are mounting it.
    mount the cat to the header
    mount the mid-pipe to the cat and hang it.
    mount the axel back/muffler section and hang it.
    then conenct the two pieces in the axel area.
