JDM H series engines have Cam sensors?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by lithiumus, Mar 9, 2007.
  1. lithiumus
    lithiumus New Member
    Toronto, Canada
    Does anyone know if JDM H series motors are missing a Cam sensor? The Crank sensor seems to be present and sending signal...
  2. alterdcreations
    alterdcreations Member
    Gettin lost in N.Y.
    Its located in the dizzy in all obd1/2 engines
    the crank sensor in in the dizzy in obd1 and at the crank pully in odb2
  3. lithiumus
    Toronto, Canada
    OK. I just want to be 100% clear so I'm not misinterpreting the info... for clarification.
    The 3 sensors in question are as follows and in USDM motors located as follows...
    Located in Cam / Crank, Belt, Pully
    CKP = Crank Position Sensor
    TDC = Top Dead Center = Cam Sensor
    Located in Distributor
    CYP = Cylinder Position Sensor
    So does this mean that OBD2 JDM motors have...
    So I should expect that a JDM distributor have additional signal wires for the TDC / Cam Sensor or is the TDC cam sensor actually replaced by using the CYP?
  4. lithiumus
    Toronto, Canada
    Update...
    I believe all the sensors are in the distributor even for OBD2. According to my mechanic, CYP, TDC and CKP are all in the dizzy.
