dude you can use your internal coil...you dont need shit. and if u put msd get the us dist. cap from autozone thats what i did so that you can hook up an external coil, simple.Quoted post[/post]]
so are you saying that i will not be able to use the distributor that came with it..my cousin is coming over this weekend to do the swap so i don't have much time to go searching for parts.
thanks
Quoted post[/post]]
no place to find out. you just gotta hope the guy with the prelude took the bus a lot.
your really lucky to have a car that already has an internal coil. i keep having to replace my wiring cause its so close to my header.
Quoted post[/post]]
Quoted post[/post]]
thanks for alll your help with the clutch and dist. cap.
i am putting this into a '92 prelude type s, but i ran into a problem when i took out the cv axle they are different length. the jdm cv axle are shorter then the one i have on my old motor. Which one is the correct one to install.
also i notice that od2 requires 2 O2 sensor on the exhaust, but i have only one on my stock how do i fix this.
does anyone know where i can get wire harness conversion from obd1 to obd2. i live in sac and need it asap since this is my commuter car.
Quoted post[/post]]
Quoted post[/post]]
Quoted post[/post]]
You dont need a conversion harness just for an o2 sensor.... Is the ECU obd1? If the ecu is obd1 it is only lookinf for one o2 so you can plug the other bung. If the ECU is obd2 and you bought it from a reputeable jdm motor retailer give them a call and ask to swap ECU's asthey should have asked you to specify the the car and year so that they would send you the right ecu.
