jdm H22 swap not sparking
MJT805
I've put a JDM h22 in my 93 but i can't get a spark. I replaced the whole distributor, cap, rotor, and external ingition coil, and still nothing. heres the rundown:
Motor is JDM h22
i bought the rywire vtec harness
p13 ecu (usdm, may be an issue..?)
distributor is from autozone and i got the one for the h23 using the external ignition style(also may be an issue..?)
also, could anyone take a picture of their distributor wire harness plugs so i can see the wires and their places in the plug?
The plug wires came with the motor. i bought a usdm distr. from autozone sat. that uses the external ignition coil and that is not working. the oem distr. was shot. the motor was steam washed and water go into the dizzy, also must of had some cleaning agent cuz it was a little corroded also.
get the internal coil dizzy
did you tell them what engine you have
they probably gave you what was for the engine that was in your car.
