jdm h22a 95 in accord 94
Discussion in 'HYBRID -> BA-BB /CA-CD' started by xela_127, Aug 17, 2005.
  1. xela_127
    xela_127 Junior Member
    hi guys thanx alot for all the answer you provide me they have been really helpful. but there'S one thing wich ain't right. i wrote a topic about axle and half-shalf. let me remind you. i got a jdm lsd tranny that came with the half-shalf. i was running automatic now it's manual. the axle on the passenger side is an accord axle wich is the same from manual to automatic. i heard i have to use all accord axle. so i bought a new axle for driver side for a manual. wich is suppose to fit. but there is the problem : the half-shalf 1 side to tranny the other is a male end. so i figure i need a female axle for the driver side to plug on the male side of the half-shaft but what i got instead was a 2 male end axle.
    so are prelude and accord manual axle really the same?
    what's my problem? the axle or the half shaft?
    do i have to use accord half-shaft?
    thanx guys!!!!!
  2. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    i have a 94 accord with a 94 jdm h22 (5 spd) and i used both of the prelude axles...they are stronger. i also used the prelude half shaft. i didnt have any fitment issues...i dont know if the auto and manual axels are different but mine worked fine.
  3. xela_127
    ok thanx i'll try that tommorow morning (i'll call napa to see if the prelude axle is female at the half-shaft end) can you answer that question?
    any 1 else got something to say?
  4. powerdriverh22
    spfld, mo
    the prelude halfshaft has a male spline and will meet with a large female cv joint caseing. hope that helps
  5. tab
    tab Super Moderator
    Aberdeen, Washington State
    use the prelude half shaft and either prelude or Accord axles for a manual transmission. They are the same.
  6. xela_127
    ok thanx guys i think that they sold me the wrong drive axle even though i chek the part number to be sure so i guess they must have a wrong listing
    thanx guys been really helpful!
  7. powerdriverh22
    spfld, mo
    let us know how it all goes
  8. xela_127
    ok i went to napa today to get to good drive-axle. when i ask for an accord one they gave me a 2 male end axle. so i ask i'm to see what the prelude 1 look like and it has 1 female end with 1 male end.(finally the one i needed). so how come all of you guys tell me that accord axle would fit? maybe the canadian model of the car witch is EX 2.2l non v-tech as a not the same half-shalf. i guess to canadian version as a half-shalf wich is female end to the axle. anyway let me know what you think about that!
    i'll get the prelude 1 tommorrow hope it fits!!!!
    thanx!
  9. powerdriverh22
    spfld, mo
    the accord passanger axle is the only one that will fit the driverside accord axle wont. the prelude axels will be much stronger anyway. im sure those will work for u!! i did the same swap about a year ago. your gonna love it!
  10. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    They're the same axle.
  11. powerdriverh22
    spfld, mo
    so if they are the same why are they different part numbers?????? if the are the same axles then why does the driver side have a female recieving knuckle(prelude) insted of a male spline(Accord).... if they are the same then why is the prelude axle thicker than the accord.....THEY ARE NOT THE SAME
  12. xela_127
    i would tottally agree with that they are not the same!!! not on canadian model anyway! thanx for all i'll be running the car today thanx!!!
  13. powerdriverh22
    spfld, mo
    just wait till you hit vtec for the first time it feels great....glad to see you got it up and running
  14. dohcvtec_accord
    The left lane
    I'll tell you what I know from my swap:
    95 Accord, JDM H22A
    I used the halfshaft that came with the engine. I then plugged my Accord axles into the halfshaft and transmission, and fired her up.
    I compared the Prelude axles that came with my swap (broken/cut) with my Accord axles. They were the same thickness. The Prelude axles are not thicker.
    If you go to Napa, and ask for either a 92-96 Prelude axle or a 94-95 Accord axle, you will get the same axle.
    Perhaps there is an issue with newer Prelude engines and/or newer Accords. I'm not sure. But believe me, 4th/5th gen Accords and 4th gen Preludes share the same axle, at least as far as the refurbished world is concerned.
  15. powerdriverh22
    spfld, mo
    how about u drive over to honda get the part number and tell me what you get im gonna put money its different part numbers. accord and prelude axles are not the same...lets see f22=130hp JDM h22=200 hp the h22 has tons more torque as well. prelude axles are different thickness and strength and are not the exact same. i have a 94 accord with a 94 jdm h22 this is not the only one i have done....im thinkin you got your axles mixed up because the accord driverside axle wont work
  16. evoracer03
    evoracer03 Senior Member
    they are not the same axle, no matter which way you look at it... the prelude shaft is thicker than either the 4th or 5th gen accord axle, and they are also longer than the 4th gen accord axles.
  17. powerdriverh22
    spfld, mo
    thank you finally someone agrees with me!!!! thanks for your input!
  18. dohcvtec_accord
    The left lane
    You shouldn't be speaking in horsepower numbers. Horsepower doesn't stress axles - torque does. So NOW let's look at those numbers:
    JDM H22: 161 foot-pounds
    USDM F22: anywhere from 135 foot-pounds to 141 foot-pounds
    Believe me, Honda isn't going to agonize over 20-25 foot pounds of torque. If you think you need thicker axles to manage 25 foot-pounds of torque, then my WRX should be sporting upgraded axles to manage the 55 more foot-pounds over stock I'm applying to the wheels. :)
    BTW, I couldn't get the axles mixed up: Both of the Prelude axles were cut when I got my swap. As I mentioned, I took my Accord axles and plugged them into the halfshaft. I suppose it's possible that I somehow managed to use the Accord halfshaft on the H22 block (this was 4 years ago), but I seem to remember the bolt holes not lining up.
  19. powerdriverh22
    spfld, mo
    you know what if it makes u feel better then ur right. im wrong cause i havent ever done 5 of these swaps. maybe you had a diff trany but im telling you the 5 i did i used all JDM prelude parts.
  20. dohcvtec_accord
    The left lane
    This isn't a question of my feeling better or being right. I'm simply telling you how my swap went. I did it myself. I didn't buy new axles. Really, I wish I could remember back so that it was crystal-clear, but I can't.
    Things I KNOW:
    - I used my Accord axles
    - the Prelude axles were cut, so I couldn't use them
    - the Accord halfshaft wouldn't bolt to the Prelude block
    - I had the M2A4 non-LSD tranny
    Things I can't remember for sure:
    - whether we somehow made a bastard of the Prelude and Accord halfshafts to make them work, if we ever had a problem with the Accord axles not working in the first place
