Jdm H22a Helppppp!!
Discussion in 'HYBRID -> EG-EK / DC' started by sh0rd87, Sep 8, 2007.
  1. sh0rd87
    sh0rd87 New Member
    we just put my h22a in my 98 civic ex and it ran fine but felt like i had no power in low rpm's and this morning on my way to work my car runs like shit and felt like i was driving with my brakes on. the car wouldnt go unless vtec kicked in and then it went fast but other then that the car felt like i was towing a tractor trailer. what can be wrong?
  2. sh0rd87
    sh0rd87 New Member
    ******UPDATE******
    When i wholeshot the tire will spin not even the whole way around and then the car bogs down and wont run smooth at allllllllll
    *UPDATE*
    check engine light is reading Code 12 Exhaust recirculation system
    could my timing be off on my car? we didnt touch the timing when we did the swap but do you sometimes have to adjust it?
    Please feel free to tell me what you think everyones opinion helps
  3. reikoshea
    Dallas, TX
    dude, i had the same problem and i dont know what the hell fixed it.
    I replaced the map sensor, egr valve, main relay, fuel pump, and got a chiped p28. One of those fixed it. Im willing to bet that it was the ECU though.
  4. sh0rd87
    sh0rd87 New Member
    i will try the ecu tomorrow after work i hope it works, i am so bummed out right now i havent had my car for a month now
  5. reikoshea
    Dallas, TX
    from what i understand its a fairly common issue with jdm h22s. This is probably the 30th thread ive seen since ive been on the board.
  6. sh0rd87
    sh0rd87 New Member
    i got my motor from hmotorsonline.com and it came with an ecu, you think it could of been a bad ecu? i wont know until tomorrow if it works or not because thats when my friend gets back. i got a p13 now and im pretty sure he has the same
  7. reikoshea
    Dallas, TX
    i had a p13 too, and it didnt start working right until i put in the chipped p28.
  8. kou
    kou New Member
    Just out of curiosity, how did you fit the H22 inside the civic chassis. I'm planning on going H22 in the near future.
  9. reikoshea
    Dallas, TX
    might wanna start a new thread.
    Im sure weve got some on this already though.
  10. sh0rd87
    sh0rd87 New Member
    it fit pretty nice with hasport mounts all we had to do was dent in the left side 2 inches below the motor mount about a half inch for the trannys accessories could fit, other then that who ever says it wont fit just doesnt want to lose to you
  11. sh0rd87
    sh0rd87 New Member
    i got a friend with a gsr with the p28 im going to ask him if i can try it out, thank you very much for you help ill keep everyone updated on the results
  12. reikoshea
    Dallas, TX
    DO NOT drive on a GSR mapped p28.
    I hope you read this before you drive that....
  13. sh0rd87
    sh0rd87 New Member
    k thanks i didnt try it yet.
    ill try my friends h22a ecu in his accord tomorrow and see how that runs then.
    i just cant wait till this is all over and my babys a beast again haha
  14. chaindtoarock
    chaindtoarock New Member
    I had this problem with my H22A from hmotorsonline. Code #12. Replaced the EGR valve and it fixed the problem.
  15. 1988hondacrxsiR1
    1988hondacrxsiR1 Banned
    Midwest
    IF YOU SAME PROBLEM REPORT TO HMOTORSONLINE ABOUT YOUR CONCERN AND THEY MUST GIVE A NEW USED ENGINE FOR A FAULTY ENGINE IN THE FIRST PLACE:cool:
  16. sh0rd87
    sh0rd87 New Member
    yeaa?
  17. 1988hondacrxsiR1
    Midwest
    I Reported A Missing Oil Pressure Sending Unit Sensor And Gave Me One New Free Of Charge And Reported A Missing Knock Sensor Free Of Charge. You Pay What You Are Suppose To Get! Good Luck Man!;)
  18. Dasfinc
    Dasfinc New Member
    You are like hard-core post whoring man...
  19. sh0rd87
    sh0rd87 New Member
    i used my friends p28 from his gsr and it made my car run smooth so that has to be the problem like everyone said im going to find a chipped p28 for the h22
  20. 1988hondacrxsiR1
    Midwest
    DON't find a chipped p28 find a default p28 and have it built especially for your setup to control your needs. GOOD LUCK!;)
