JDM ITR pistons
Discussion in 'Engine Building' started by EG6_down5hift, Mar 14, 2004.
  1. EG6_down5hift
    EG6_down5hift Junior Member
    Would the JDM ITR piston be a direct fit to the GSR rod and plug in? I wanted to slap on the slugs and run them on CTR cams.
  2. SixtySecondAssassin
    Austin, TX
    yes
  3. EG6_down5hift
    do i use the ITR piston pins? About the CTR cams, do i have to use CTR valvesprings? i'm thinking of beefing up the valve train for higher RPM capabilities.
  4. GSRCRXsi
    MD
    yes, any pistons you buy should come with new wrist pins anyway
  5. EG6_down5hift
    on sugesstions on the CTR cams
  6. pissedoffsol
    at least run itr or ctr valve train, or upgrade to toda, skunk2, etc
