JDM ITR swap into 95 GSR - harness/obd wiring?
Discussion in 'HYBRID -> EG-EK / DC' started by darlix, Jan 19, 2004.
  1. darlix
    darlix Junior Member
    My mechanic is putting in a 97 JDM ITR engine into my 95 GS-R.
    The swap comes complete with OBD2 and harness
    I would like to keep the GS-R ecu because it is easier to tune later on.
    Any suggestions as to what has to be done?
    thanks
  2. highperboi
    highperboi Senior Member
    Alameda, California
    so you have a obd1 engine with a JDM obd2 type R harness and a obd1 gsr ecu?
    unless your car is right hand drive i dont think a jdm harness fits your car.
    and if you wanna use the gsr stuff i say switch to a gsr harness.
  3. E_SolSi
    distributor
    fuel injectors
    alternator
    those will be your only issues
    either swap the parts for your OBD-1 peices, or swap the plugs from the JDM harness
  4. NoJokE
    NoJokE Senior Member
    Use the GSR's engine harness, the GSR's distributor, and the GSR ECU and you're good to go.
    What happened with your GSR engine? Did it blow to pieces or something?
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    :ditto:
    use the gsr dizzy, gsr alternator, injectors. I would also run an ITR base map on either a p28 or your p72 ecu
