JDM K20A motor in a 92 accord?
Discussion in 'Accord' started by grndmstr16, Aug 31, 2006.
  1. grndmstr16
    grndmstr16 Guest
    Would it be possible..... if so what would it take..... Would it be advisable..... I primarily want it for its horsepower rating and the i-vtec..... The h22a type s has the same hp but i leanin towards the k20a because there backed by jackson racing products..........?
  2. SmokinH22CL
    SmokinH22CL New Member
    Florida
    anything is possible with the right amount of money, and with that type of money i would just go with the h22a and build it IMO
  3. BrutalB83
    BrutalB83 Guest
    What do you mean they are "backed by Jackson Racing Products?" If you mean that Jackson makes a blower for it then the H22a Type-S is backed by Jackson Racing Products as well.
    To answer your question, it probably will eventually be possible to swap K-series motors into the 90-93 Accord. Hasport already has a mount kit in production for the 94-97 models, and it is rumored that they will be coming out with a kit for the 4th-gen Accords as well.
    As of right now though, nobody makes a mounting kit or conversion harness so if you want K-series power in your CB7, then it would need to be a fully customized job. You'd probably be better off with an H22 and turbo.
  4. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Boost the F22, cheaper and more power.
  5. grndmstr16
    grndmstr16 New Member
    im not really into the whole turbo scene ( I know - I know ) so if the h22a can use the jackson racing supercharger and such then i might lean in that direction...... at least until hasport makes some mounts...... thanks if anybody else has anything else to add fell free its apreciated.
  6. Turbo&Auto
    East Burg, PA!
    No turbo but a s/c, that makes sense........
  7. alterdcreations
    alterdcreations Member
    Gettin lost in N.Y.
    i think hasport made a kit to mount it in a 94-97 accord.
    should beable to re fit to 1990-1993 with the change of one mount.
    i would do it if i can
  8. BrutalB83
    Rochester Hills, MI
    Yeah that's what I was talking about in my post above. They haven't even released the 94-97 kit to the public yet though, so anything at this point would have to be a custom job.
