JDM or USDM
Discussion in 'General Tech and Maintenance' started by mdlax1, Aug 1, 2003.
  1. mdlax1
    mdlax1 Senior Member
    On the Proverbial picked fence of Insanity....
    Ok so i have a US ITR in my 99 coupe. I'm running a 99-00 SI Harness.. and a 00 B16a2 ecu.
    here's my question. I have a v-afc.. blah blah blah
    im aware that the us itr doesn't produce power after the 8,400-8,500 rpm. well im getting the ITR ecu i have a choice between the JDM or USDM with the imob and pin taken care of already..
    so which do i get.. dont just answer JDM JDM cause it's jdm but i need the tech side of this guys thanks
    Eric
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    i say get the USDM for 2 reasons
    1.) you already have a USDM motor, might as well match them
    2.) you wont have the shitty 115 (or 105 i forget which) mph speed limiter the JDM ecu's have
  3. mdlax1
    the JDM has a govener??? i didnt' know that.
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    yep it is acutally like some odd number (like 112 or 114) but in any case, extremly low.
  5. mdlax1
    so what frey tell is the usdm one?
  6. B16
    yay area, CA
    what is frey tell?
  7. mdlax1
    whats the usdm speed cut off
  8. word
    word Senior Member
    USDM has NO speed limiter. Also, the JDM ecu is programmed for a much higher octane level (like 99 or 103, I forget) than the 91-93 here in the US.
  9. mdlax1
    so general consensus is usdm
  10. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    or you just go Hondata like I did with my JDM motor
  11. MXDesa
    MXDesa Senior Member
    Queens, New York
    Do speed limiters on the ECU's go just for the JDM ITR Ecu or does that apply to all JDM ECU's?? And do all USDM ecu's have no speed limiter??!
  12. mdlax1
    if and when im ready for E. M. im going tec 3 lets you change it all and doesn't rely on someone programming it.. more hands on
  13. jeffie7
    Maryland
    make sure you know what your getting yourself into
    its a great system but Im not sure why you would want it
    Tempest uses Hondata for most of their cars but they did use a Tec 2 system on the prelude and type R only reason being is the type R was making 450WHP on pump gas and also running N20 and the prelude put out 750HP with a very tiny turbo that use to be on a civic
    but as for the 300-400WHP cars they all run Hondata very easy simple and clean
    plus you still use all your normal things like check engine light so its easier to track down problems just running the ECU codes
    I have a sleeved, pistons, rods, headwork and tons of other little things APR headstuds and such motor and it has NEVER crossed my mine to run tec2
    I love my hondata =)
    Jeff
  14. jeffie7
    Maryland
    Im not fully sure but I don't believe that is true
    one thing to back it up would be just think about how many people do JDM swaps and use JDM ECUs if it was really a problem Im sure you would have heard tons of people on hondaswap asking why is it not running right....
    I have a JDM B16 I've run a few ECUs
    Civic EX
    GSR
    Type R
    racing spec GSR
    and SIR
    right now Im running a fully custom fuelmap but when it was all motor for the most part I ran the JDM spec civic SIR with 8500 revlimit and also no speed gov
  15. B16
    yay area, CA
    yes, from what i've heard all JDM ecu's have the same speed limit. i know USDM ones have speed limits, i'm not sure about the ITR one.
  16. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    dont' bother with the J ecu's. The limiter is at 180Kph. If you want a decent starting point get a p28 and put a ITR base map on it for the mean time. Then add hondata, and fine tune shit out.
    Milan
