jdm pw3 ecu, chipping options...
Discussion in 'ECU's, Electronics, and Tuning' started by goldgreen90ef, Apr 24, 2007.
  1. goldgreen90ef
    goldgreen90ef goldgeen90ef
    cold ohio
    i have a pw3 ecu running my b16 swap, and i want to chip it. i want it to only look for one 02 sensor, lower the vtec, and raise the redline. whats a good company to do this??,,,and i dont want to go obd1,thanks
  2. P7ank5te7
    P7ank5te7 New Member
    Radford, VA
    Have you done anything to the motor? And with OBD2 I'm not too sure if you could get away with it looking at 1 O2 with out possibly maybe an O2 simulator, but I could be wrong. As far as raising the redline, if theres not really done, is there really any reason to be going into it? -Gary
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    does that ecu even exist? you sure you aren't mistaking it for a pr3 or a pw0?
    couple more points, if you lower the vtec, you will be slower, if you raise the redline you'll blow your motor... that is if your motor is still stock.
  4. goldgreen90ef
    cold ohio
    yeah. sorry it is a pr3, the main thing i want to do is have the ecu look for one o2 sensor, any suggestions, thanks
