HatchSpeeD
...Hi...
Ok, I heard a couple of things and want to put this to rest.
If I were to purchase a jdm engine, would I be able to use the engine wire harness it comes with?
I heard some crap that you can't because it is setup for RHD. Is this true?
Also, jdm engines often have a higher compression ratio then usdm, and I heard they require a higher octane of gas then usdm. So does a STOCK JDM b16/b18 require the higher octane?
Thanks
Thanks
