JDM sidemarker wiring
Discussion in 'ECU's, Electronics, and Tuning' started by seanjuan, May 24, 2005.
  1. seanjuan
    seanjuan Senior Member
    Twin Cities, MN
    so I'm trying to figure out how to wire up these side markers and wondering if anyone here knows how these sidemarkers are supposed to work
    are they just supposed to be on all the time with the parking lights?
    are they only supposed to come on when the turn signal is on?
    or are they supposed to be on all the time and get brighter when the turn signal is on?
    if it is one of the first two I can handle that
    but if it is the third then I'm wondering how that is supposed to be wired up?
    do you just run a power wire from the parking light and from the turn signal to the positive lead on the side markers?
    any help would be nice
    I have a pretty good understanding of circuits and the whole parallel, series blah blah blah because I had to take some circuits classes at the UofM for my Mech. E. degree
    thanks
    Sean
  2. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
    they are on with the turn sig only
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    :werd: :withstupid: :thumbsup:
    Yip, they are OEM here.
  4. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    well i do alot of night driving so i have them on all the time and the blink...i do this in hoping that it gives more light to my car so big mother truckers can see me
  5. baker423
    baker423 Senior Member
    Upstate New York, 14882
  6. n1mr0d
    n1mr0d Senior Member
    Channahon, IL
    Speaking of. I thought that the stock location of the eg amber side markers was the front trim pannel piece? You pop that out and cut the hole to fit the eg markers? Am I worng? I didnt think that it was above the trim piece on the fender?
  7. xj0hnx
    C.C.TX.
  8. civic92jak
    civic92jak Senior Member
    ^ is the right place and you can wire them three different ways.
    1. Only blinks-ground and green
    2. Stays on only-ground and red
    3. On and blinks-green and red
    I have mine on and blinking also.
  9. seanjuan
    Twin Cities, MN
    so you have the power lead from the parking light and from the turn signal both wired to the positive terminal of the side marker?
    and you don't have any problems with bulbs burning out or anything?
    this is most likely how I'll wire mine up, I think it will help with visibility as you said
    thanks guys
  10. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    my crx has had them on for a year and a half and my del sol has had them for a year and no problems....soiler all my connections and heat shrinked them and no problems what so ever
  11. xj0hnx
    C.C.TX.
    If a car can't see you headlights, than having little lights on teh side isn't goiing to make them see you, just wire them right, don't be a dork.
  12. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    ok if they are next to i think it would...if having extra saftey ideas makes me fell beter makes me a dork then i am a dork.
    his are clear anyway...mine are the real deal from japan
  13. baker423
    That def makes you faster and more JDM than anyone i know! <_<
  14. civic92jak
    I don't have any probs with builbs burning out. And i am a "DORK". I like the looks of them being on at night with the other parking lights.
  15. xj0hnx
    C.C.TX.
    Or, maybe like the LED nozzles for your windshield washers, and underboby neons, they could distract other drivers.
  16. jdmlovingcrx
    jdmlovingcrx Member
    cincinnati
    ok????? i doubt that or they would be illegal(as they are in the fine state of ohio)
    and if they are distracting to ppl like you, you should not be on any road anywhere...i bet looking at christmas lights is distracting to you.
    one word....multi-task
  17. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    multi-tasking and distractions are different. a distraction distracts you from a task... :)
  18. xj0hnx
    C.C.TX.
    I'll multi-task your ass in circles. If you want to wire your lights wrong, and look like some moron ricer that doesn't know how to do things correctly, go right ahead.
