Ok I have a 97 civic ex and I threw a rod. I am looking to do a b-series swap.
I found a JDM b16a (2nd generation). My question, after reading the Swap Articles, is why is the b16a2 the better swap for a 6th gen (96-00) civic? The b16a2 is obd1 and the 6th gen civic is obd2; Right? And would the JDM b16a (2nd gen) swapped from: JDM Honda 92-95 civic SiR2, 93-95 Del Sol VTEC, be considered a B16A2 as the JDM motor is OBD1, as said by Totaljdm.com?
Also Totaljdm.com says all I will need is a wiring harness (I guess different from the one included in the swap) and it should be a completely bolt-in swap. What do you think?
This is definitely the most informative forum I have ever been apart of.
Thanks for your help!
