job gone bad
Discussion in 'Engine Building' started by 92b20mao, Jul 21, 2003.
  1. 92b20mao
    92b20mao Junior Member
    I recently had a valve job done by a shop and i think they f up some how.
    My b16 head with a stock b20z bottom end snap the valve and dropped in the chamber. They replaced all the valve train parts w/ crower parts and ferrea valves and all seat springs and retainers. Some how after two - three weeks later the 1st cyl dropped(snapped). Then when i took it to a shop they said the intake valves were hitting the pistons. Does anyone think that the 1st shop f up putting the parts in wrong.
    By the way they put the whole motor together
  2. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    ummm yes if they asjusted them wrong...
    no if you messed up the timing in some way after the job was done.. E.I. advacne or retard.
    maybe you should ask them if it was there fault
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    If I am not mistaken there is a way to check to see if the valves actually hit the pistons. Doesn't the B20z have valve reliefs in the wrong place, e.g. hitting the valve if head is milled, thinner headgasket, more aggressive cams or advanced stock cams.
    Milan
  4. 92b20mao
    no did not adjusted ant thing on the motor just brought it back anjust installed in the car.
    I can not prove that they screwed it it and they said that since it was a race motor then it not their respondability to warrenty the work. BS
  5. 92b20mao
    just the stock crower cams. (63400), not milled, stock cam gears,
    NA on the valve relief. did not check the timing when i put it in the car
