Jumpy Tach
Discussion in 'General Tech and Maintenance' started by D See 2, Mar 13, 2003.
  1. D See 2
    D See 2 Senior Member
    Baltimore, MD
    what could cause a tachometer (both aftermarket and stock) to be jumpy. its very erratic. it didnt always do this. just started a couple of months ago. could a faulty distributor igniter cause this.
  2. D See 2
    Baltimore, MD
    no one knows what could make a tachometer be erratic?
  3. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    uhh erratic Tach could be your clutch is all done bro :)
    the clutch slips all the time, and makes the revs fluctuate, even maybe not audibly. Usually this is easy to notice because of engine noise. It all depends on how erratic and when
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    my buddys 89 tegra had the same problem we had to replace the a senor wthin the distributor which was causing a poor spark and the altinator was also bad
  5. 90 accord
    90 accord Chicks dig the box Moderator VIP
    Mesa, AZ
    i'm assuming that your engine does not rev up with the tach?
    i had a similar thing happen to me, took it to a dealership,and they said the wires that attach to the coil were comming off. they re soldered them and it works fine now
  6. enemycivic
    enemycivic Member
    Is you ecu showing any codes? This idle jumping up and down like that is one of several things to check. The IAC valve, perform a vaccum check,.
  7. D See 2
    Baltimore, MD
    its not my idle or motor...JUST the tach. the engine itself does NOT fluctuate in idle.
  8. enemycivic
    enemycivic Member
  9. jamiedude
    jamiedude Senior Member
    chesapeake,va
    my crx did that when i first bought
    my tach was moody didnt wanna work when i wanted it too
    i always caught it working when i could really careless if it did
    :angry: litte bastard :angry:
    i replaced the clutch(becuase it was shot) and it works like a champ now
    i agree with liquid00meth
  10. VtSol
    VtSol Junior Member
    It could be your coil wires. Sometimes when there is bad connections between them, the RPMs will fluctuate that way, only on the needles. Check for old or corroded wires or just bad connections in your wires.
  11. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    With the aftermarket tach, are you running right off the ECU? I would also try to use a multimeter and check the RPMs that way. It could also be a short some where. Is it all the time or just at Idel? How much does it bounce?
