Jun STage 3 cams
jdmh04
Member
Hey guys just 1 quick question will Jun STage 3 cams work well with tubo on a b20 vtec?
shitty shitty shitty shitty shitty SHITTY idea
NA cams especially that agressive SUCK BALLS for turbo applications.... shit stock cams would probly yeild higher HP numbers
get a cam specificly designed for turbo
they would work well until the turbo spooled =)
honestly
keep the GSR cams
untill you are running a disgustingly huge turbo they will be fine
if you are dead set on getting cams then look at crower
