junkyard engines..
rodvang
anyone have any idea? What will I need to complete the swap if I get an engine from the junkyard? planning on gettin a 94 ls engine from a junkyard and need to know what else I will need...thanks guys
read the articles,
if the place has the whole car, try to get the ecu and everything it says in the swap article.
2. B18B: Completely bolt-in swap, SIR II, Hasport shift linkage. Del Sol VTEC for the del sol
that is the only thing i really found..so I wont need new motor mounts or anything like that? and whhat is the SIR II?
Iight,
94+ Teg mounts-
Driverside top, front and rear trans bracket
94+ Teg Linkage
OBD1 LS ECU, pr4 or p75
I don't know what car you have but I assume it's a 92-95 civic.
