just a few questions
Discussion in 'Forced Induction' started by rex187, Aug 15, 2005.
  1. rex187
    rex187 Member
    austin,texas
    ok heres the deal im gona trubo the b16 in my crx but im having a few problems about what is all needed. so i have a few questions and what not. i hear that u need to build up the motor(like dropping the compression,new sleaves,block gard ect.) befor putting the turbo and what not on to it. is this true or do i not have to change internals to turbo it. also what all do i need for a trubo kit to work with no problems what sort.
  2. drpenguin
    drpenguin Senior Member
    Salem, Or
    You dont have to change the internals if you get it tuned right and dont put too much boost in it. should run fine on 8psi
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    I've always heared the same, if you are going to run 8 psi or less, leave it stock.
  4. formby
    formby learning in progress
    i agree and disagree....
    you will get tired of the power 8 psi gives you in less than 3 months.....then you will want more.....so then you buy a boost controller and blow up the engine...
    i would buy forged piston/rods (9.8:1) and then boost the ride....
    better safe than sorry
  5. rex187
    rex187 Member
    austin,texas
    thanks yall. what should i do about boost controller and turbo timer...whats the best bang for the buck?
  6. B16CRX
    B16CRX Senior Member
    Greenville, SC
    fuck 8 psi. I'm running 12 psi on my B16A with stock internals all day long with noproblems besides a slipping clutch. That will be changed soon. Feel free to AIM me with all your questions.... ccdamanison. My setup is in my 91 crx si.
  7. pissedoffsol
