And if you have NAWWWWS
Just kidding... had to put it, he said street races. Whatever. What cointelpro has to say is quality. So just listen to him. Good luck with the B18. Just incase no one answered your question the B18 came in four different variants, B18A1, B18B1, B18C1 and the B18C5
1. B18A1 whihc was offered in 90-93 Integra's (RS/LS/GS) and also in 2 different OBD's (On Board Diagnostics) OBD-0 and OBD-1.
2. B18B1 which Im not sure the differences between the A1 and B1 but it was offered in the 94-01 Integra (RS/LS/GS) and I think as many as 3 OBD's. those being the OBD-1, OBD-2A and 2B.
3. Also for 94-01 The Integra came in GSR trim which has the B18C1 engine.
4. The Integra Type R (ITR) came only with the B18C5 (OBD2[not sure if it's A or B or both]).
To make your swap easy, go with the OBD-0 B18A1 for wiring purposes, you'll thank me later, and also the transmission on your car is cable as is the transmission with this engine! Simplicity, oh so grand! Another swap alternative is a B16A1 SiR1 swap, which the JDM (Japanese Domestic Market) engine for your car (in SiR trim) this engine as you may know has a 160HP, VTEC and bolts in with Mounts from HASport or the like. However your car being a sedan would be refered to as the Ferio in the JDM trim with this engine. To do this swap you must convert your wire harness from DPFI to MPFI, add three wires for VTEC. Again Hope I helped.
