just bought car???
Discussion in 'Civic and CRX - EF' started by BIGROB90, Aug 9, 2011.
  1. BIGROB90
    BIGROB90 New Member
    FLORIDA
    so im new to this fourm and had just bought a crx for 1k the car has these mods.anyone can help lmk if its a great car or ill have to junk...loljdm b16a,ctr pistons,ctr cams,70mm onmi tb,skunk2 pro intake manifold,50hp shot sniper kit,weapon-r R&D titainium headers,full skunk2 exaust,suspension tecnics swaybars(front and rear),si wheels with new falkens,true jdm mugen full bodykit,and more but the problems is the ecu is funny someone steps on it it boggs down or while driving it hesitates and pisses me off?? please help
  2. Dj211855
    Dj211855 New Member
    sell me the car, i'll fix it.
  3. BIGROB90
    BIGROB90 New Member
    FLORIDA
    YEA JUST MIGHT just put new skunk2 cams in it yesterday and pulls hard but light throttle still hesitates might need a new harness moved the ecu and now works fine stumped....
  4. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    any check engine light?
    if not, get that thing tuned.
  5. reikoshea
    Dallas, TX
    hesitation at the bottom end can be bad timing or a worn out fuel pump. Another less likely (but cheaper to fix than a fuel pump) candidate is spark plug gap, or that he's running stock plugs with high compression. Stock plugs can sometimes make the bottom end a bit swiggly with high comp and a decent cam till it's tuned properly or they're replaced with a colder set.
  6. BIGROB90
    BIGROB90 New Member
    FLORIDA
    No check engine light and the car runs great good idle at 1k rpm no sputter and fast as hell just when someone touches or kicks the wires on the ecu it will drop in rpm and will want to stall at lights
  7. reikoshea
    Dallas, TX
    sounds like someone rewired the harness and you've got some loose wires/grounds.
  8. BIGROB90
    BIGROB90 New Member
    FLORIDA
    well ill just have to get a new hasport harness but its cool what do you expect for 1k and has anyone hear of twilight performance that where the motor was built
