Just curious about my B18a1?
Discussion in 'Engine Building' started by RoadRage, Oct 1, 2002.
  1. RoadRage
    RoadRage Member
    OK, Here's my question. I purchased a 90 Integra with a spun rod bearing. I used that car as a doner car for my swap in my 89 Si CRX. I bought a 92 B18a1 to replace the bad engine. Now from what I understanding, The 90-91 B18a1's only had a 130hp and the 92-93 had 140hp. I'm running a 92 b18a1 with a 90 teg ecu. Is that other 10hp in the engine or is it in the ecu, or is it a combination of both that make's that 140hp? :blink:
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    it would probably be pretty hard for a stock honda ECU to make 10 hp. i'm pretty sure the difference is from slighly more aggressive cams and slighty higher compression ratio. can anyone back me up on this? so to answer your question, the difference is probably in the motor itself. not to say the ecu's arent different but like you said it is probably a combination of both.
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
  4. ls_vtec_b18a1
    ls_vtec_b18a1 Junior Member
    i got a ecu that will give u 18 extra horse power if your interested.
  5. lsvtec
    There is no way that you can garauntee an 18 hp gain with a chip.
  6. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
  7. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    that may be one of the funnier things i've ever heard.... why not just get the thing off ebay that is just a resistor that they sell for 5 dollars.
  8. ls_vtec_b18a1
    about the chipped ecu'' thats the spec's the man from dinan said just sayn what i was told. :blink:
  9. SpecialRacer
    SpecialRacer Junior Member
    Like ONE said it has to do with the IM, cams and pistons.
