just double checking everything
Discussion in 'HYBRID -> ED-EF / DA' started by iwantawd, Apr 9, 2004.
  1. iwantawd
    iwantawd Junior Member
    if im swapping the dohc zc into a crx that came with an auto but i put in a manual there wont be any problems, it will all still just bolt up? and if its going in a dx not an si.
    also other than the engine and tranny ill just need the 88 teg ecu and wiring harness and i should be able to drive away a happy man?
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    i am not postive about EF's, but in EG's, DC's, EK's, ect, the top tranny braket (that is welded to the chassis) on the automatics, it goes upwards like / . On manual's, the bracket is horizontal and makes a 90 degree angle with the frame. This diffrence makes it so that the stock manual trans mount will not work because there will be about 2 inch gap. You need to either get that braket from a manual version and weld it in place, or buy an aftermarket mount from hasport, placeracing, ect.
  3. iwantawd
    ok and where can i find the 89 integra ecu and wiring harness id need?
  4. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    best bet is to check the junk yards and throw up a WTB post in the classfieds section of the board, also try honda-tech you may have more luck because it is a larger board
  5. ef_hatch
    ef_hatch Member
  6. iwantawd
    i havent looked at the link yet (working) but what is mpfi? im a mitsu guy and im just doing this "small" project until i get my gsx so i know nothing about hondas right now.
  7. jaydemdc2
    jaydemdc2 Member
    seattle wa
    multi point fuel injection
    your dx is duel point fuel injected
  8. iwantawd
    great links, thanks a lot for the help and i dont have a dx i was just wondering what would need to be done if i did get that. slight misunderstanding.
    what are the differences between an hf and an ex so i know when im searching?
  9. MugenCRX
    MugenCRX Senior Member
    Thornton CO
    CRX's only came in three models. SI, DX, HF. And in Japan I think that there were also three versions, the something, SI, SiR.
  10. iwantawd
    ok i was just checking because it said this on one of the links...
    CRX Si, HF, EX (Port injection)
    thanks again
  11. brian11to1
    brian11to1 Senior Member
    you dont have to do anything to passegner side mount is fine.
  12. iwantawd
    :blink: huh?
    i dont know what your talking about
