Just got the eg turbo b18 going and idle is high
pureautosports
Pureauto
Ive got everything hooked up right double check everything no vacuum leaks no leaks around intake manifold? im useing s100 do you think that the hondata could be the issue its like 1500rpm on idle we found that under boost my oil catchcan hose popped off and made a huge vacuum leak after fixing that the idle was perfect like 900rpm them 3min later iddled back up now im getting a solid 8psi and no leaks ????????????????help please!
