just joined .....saying help with honda
Discussion in 'Members' Lounge' started by jelma1854, Aug 16, 2006.
  1. jelma1854
    jelma1854 New Member
    hey everyone..... looking for info on swapping a b16b vtec into a honda crx 1988... any help info would be appreciated:)
  2. reikoshea
    Dallas, TX
    god help you with wiring.....thats really all i can say.
  3. hybrid89
    hybrid89 thistownsucks...
    SoCal
    go with a b16a1 and save the trouble and money
  4. smarty009
    smarty009 Senior Member
    Warner Robins, GA
  5. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    how is wiring any harder?
    swap to an obd 0 distributor and injectors????
    no harder than wiring a b16a
  6. reikoshea
    Dallas, TX
    a ctr is obd2, there are a few sensors that are not on your original harness, so it takes a bit of wiring.
  7. pissedoffsol
    easiest way:
    conert both the car and the motor to obd1
  8. jelma1854
    but a b16b has more horsepower i realize a b16a is easier to install but its what is wanted
  9. jelma1854
    i know this sounds a little strange.... in all of my info i can' find out what "dizzy" means
  10. reikoshea
    Dallas, TX
    distributor, its hs.com slang. most of my friends dont know what it means either.
  11. jelma1854
    ok...went to the source of honda...its a honda crx dx with a D15b2 L3 tranny...couple of ??? 1. if i use a b16a1 with a comprable tranny will it fit in the crx....2. what tranny is compatable as a L3 and 3. how do you remove a 120 mph limiter in a car
  12. reckedracing
    reckedracing TTIWWOP VIP
    NY
    1, yes it will fit
    hasport.com for mounts and installation instructions...
    2, a cable B series trans, found on imported motors, or 2nd gen integras
    3, computer work removes the limit
  13. jelma1854
    one more ? will a b16b fit in the same car
  14. reikoshea
    Dallas, TX
    the question is not whether it will fit, the question is, how comfortable are you with rewiring your engine bay.
  15. jelma1854
    thank you for the info....i am going to assume then that the best way to go is use the b16a series... the swap package i am looking for has to have a 5 speed trans ...any suggestions on where to "shop" for... best prices i guess with best warranty
  16. reikoshea
    Dallas, TX
    hmotorsonline is the place to go. most of us that have swapped got our motors from steve, and in the end, best customer service and quality of product. if that means i have to pay 100ish more dollars for a quality product, then i will.
  17. jelma1854
    thank you for your help
  18. lmn8
    lmn8 New Member
    Las Vegas, NV.
    what the F#ck it's not that hard just cus the b16b has diff and extra sensor' dont mean sh#t you can wire it just as easy. look bro convert obd1 just get the wiring kit from HONDATA.COM it's no biggie
  19. turbo tegra
    turbo tegra New Member
    NJ
    I Say U Should Convert To Obd1 And Get A Gsr Lot More Power Lot More Fun
