I have a 94 civic ex which as most of you know has a d16z6 (SOHC Vtec, OBD1).
I am going to order a SiR II complete motor swap(OBD 1)
Here is a list of what comes with it:
Engine
Transmission 5 Speed Hydrulic
ECU
Disterbutor
Alternatur
Starter
A/C Compresser
Power Steering Pump
Intake Manifold
Exhaust Manifold ( JASMA HEADER )
Down Pipe
Half Shaft
Axles
All Sensors
Clutch
Fly Wheel
Pressure Plate
Shift Linkage
Do i need a wiring harness? Mine is already wired for Vtec.
What else will i need to make this swap as easy as possible?
Thanks and God Bless
Leon
Engine
ECU
Disterbutor
Alternatur
Starter
A/C Compresser
Power Steering Pump
Intake Manifold
Down Pipe
Half Shaft
Axles
All Sensors
Clutch
Fly Wheel
Pressure Plate
Shift Linkage
Leon
