Just to verify somethings...
Discussion in 'HYBRID -> EG-EK / DC' started by xtnod, Jan 8, 2009.
  1. xtnod
    xtnod New Member
    Okay here is my setup:
    CAR: 96 OBD2A civic EX.
    ENGINE: 95 OBD1 GSR Shortblock+Tranny with 00' Si B16 Head
    ECU: JDM P30
    Just to verify/clearify if I've got everything correct before I go on ahead and starting working on it.
    1. I will be using my EX engine harness, but with a Jumper Harness OBD2A->OBD1 for my JDM P30 ECU.
    2. I would NOT need to change my injectors since the head is OBD2.
    3. The Distrbutor should also not change since it'll also be OBD2
    4. As for the mounts I've been told I would need to aquire some OBD2 engine mounts for the engine to fit my chassis. Like mounts from a 99-00 Si.
    5. Extend the VTEC line to actually reach the VTEC Sol. seeing as my B16Y8 is a lot shorter.
    6. And of course B18C1 shift linkage and axles.
    Now something I am not too sure about is how my Apexi WS2 exhaust is going to connect to it, or rather what header to use. I know it's either going to be a B16 header or a B18 header just needed that verified.
    Anything else that I am missing or forgot please do say.
    Thanks in advance.
  2. Matts96HB
    Matts96HB . Moderator VIP
    Everything sounds/looks good. You have a D16Y8, not a B16Y8.
    B18C1 linkage, axles, and B-Series mounts.
    Use the injectors that come with your swap.
    Use the dizzy that comes with the swap (if applicable)
    If I remember right, your Dizzy and ECU must be the same OBD, but let me check on that.
  3. xtnod
    xtnod New Member
    oops yeah lol meant D16Y8 I typed this on my blackberry so haha.
    Also anyone have experience with a Kaaz LSD? A buddy of mines is willing to sell his GSR transmission with the Kaaz LSD to me.
  4. 95b16coupe
    95b16coupe New Member
    ct
    kaaz is VERY reputable. how much is he selling it for? do you trust him to sell you a smooth tranny?
  5. austin20110
    austin20110 New Member
    Northern Va
    OBD 2 to OBD1 is illegal I thought. Atleast thats what E told me
