K series in the Del sol and others
Discussion in 'Civic and del Sol - EG and EK' started by Hatchattack02, Feb 25, 2008.
  1. Hatchattack02
    Hatchattack02 New Member
    I know this has proballly already has been answered but I need some serious help expert help.
    Im wanting to buy a Del sol and i want to put a K series motor in it prob the k20a2 with a supercharger. I want to know if any of you know how hard this swap is cuz im not that experinced but i can get experienced help. i want to know wut mods i have to do to get this engine in?
    I am also considering the b16a Sir II it makes 170 hp i know i can change the internals and get more but i dont want to be slow and dont want to get a turbo and put throw alot of money away ( I know the pros and cons of turbos but i want a SC) So i want to know if there is a super charger out for this motor is its intake diferent from the regular b16a?
    And if it was you wut motor would you put in there with a SC to make the most power my budget is 7k but i can always put more into it that is just wut i will have.
    Any expert knowldge about this swap would be awsome thanks Chase
  2. eg6sir
    well, lets put it this way.. a k20 swap alone will run about $10k seeing that you probably wont be able to do the work yourself..
    i'd go with a b18c (GSR) swap
  3. Hatchattack02
    How much power does the b18c gsr make?
    And why not the k20 is it a hard swap?
  4. eg6sir
    b18c gsr makes 180hp .. good for all motor or FI
  5. Hatchattack02
    Who makes a super charger for it?
    I really want to turbo but everytime i say that someones like nah man thats to much money but i think with the right tune it wont be to bad =/?
  6. 92civicb18b1
    92civicb18b1 The Trisexual
    Turbos are cheap, a lot cheaper then a supercharger and have more potential and will in the long run make more power.
    But if you insist on an SC, Jackson Racing makes a SC kit.
  7. Hatchattack02
    Yea i know turbo makes the most power less strain on engine all that and i would rather have a turbo more but i dont wan2 have to work on it all the time and lose a bunch of money but if i do it right it shouldnt be bad idk wut im gunna do
    And SC for the b18?
  8. 92civicb18b1
    build it correctly and tune it correctly and you won't have reliability issues.
  9. Hatchattack02
    yea i know...do you know anything about the k20a2 w tranny bein put in a del sol?
  10. eg6sir
    :search:
    this subject has been covered a millions times.. if you google k20 swap it'll pull up something
  11. 92civicb18b1
  12. Pvtjoker122
    Pvtjoker122 New Member
    San Diego, CA
    I would also have to say go GSR swap, and turbo it, or throw a supercharger on it. But if you insist on K20, then go for it and good luck. I'm not sure how hard the swap is, but a Hasport mount kit would be a good start, and Hasport has axles and shift linkage too i believe, and then just get some good engine management. But yea, K20 would probably be the most expensive.
  13. Hatchattack02
    Yes i know but i cant find one that says anything about a k swap into a del sol that actually answers my questions
  14. eg6sir
    it would be the same as a 92-95 hatchback
  15. Hatchattack02
    Is there a turbo kit i can get for the swap that doesnt need any custom mods to fit? IF so wut turbo kit?
