K-Tuned Parts Available At CorSport (K-Tuned Authorized Dealer)
Discussion in 'CorSport' started by CorSport, Oct 28, 2011.
  1. CorSport
    CorSport Member
    K-Tuned Parts
    [​IMG] [​IMG] [​IMG]
    K-Tuned Parts
    Click here to see this product in our catalog and check out the most current pricing.
    K-Tuned has it's roots firmly set in the import racing scene. With over 15 years of experience building and tuning cars, we have laid a solid foundation when it comes to designing quality and innovative products. And with the inception of the K-Tuned
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
  2. CorSport
    CorSport Member
    K-tuned K-Swap Package Level Four
    [KSP-04] $2,703.00
    CorSport: K-Tuned - KSP-04
  3. CorSport
    CorSport Member
    K-Tuned parts in stock and ready to ship.
  4. CorSport
    CorSport Member
  5. CorSport
    CorSport Member
    02-06 Acura RSX & Others w/ K Swap K-Tuned Race-Spec Shifter Cables and Trans Bracket
    [​IMG][​IMG][​IMG]
    To go along with our popular Billet RSX Shifter Box we are pleased to offer our K-Tuned Race-Spec Shifter Cables and Trans Bracket set. This is another part that many of our vendors and customers asked us to make, so here they are. Our cables are a super strong and stretch resistant replacement for the weaker and failure prone oem 02-04 RSX-S cables. The overall length is the same as oem and they are compatible with all oem and K-Tuned Shifter boxes, as well as many other aftermarket shifter box options. Our cables are also more flexible than oem cables and feature the fit and finish that you have come to expect from K-Tuned products.*
    K-Tuned Race-Spec-Shifter Cables are made almost entirely of stainless steel, including the very important inner cable and all of the exposed cable guides. The outer cable is constructed with a low friction Teflon coated inner liner and a heat resistant polyethylene outer covering. Even the cable mounting ends are made from stainless steel and were designed with a threaded section to eliminate the need for the oem cable clips. However, take note that the oem clips can still be used if desired. Last are the rod end connections, these are fully adjustable and made from 6061 billet aluminum at all four ends. We made one minor adjustment at the gear selector, here we are still using a billet rod end, but we added a spherical Delrin insert to allow proper movement at this joint. Allowing this movement helps reduce possible cable bind during shifting. There is even a bonus, because we have also included our Billet Cable Bracket to make this a complete package. We are so confident in our shifter cable design that we even offer a 1 year replacement and limited lifetime warranty. If you are looking for the best K-series shifter cables available, your search is now over.*
    Features:
    - Perfect accessory for our Billet RSX Shifter Box
    - 1 year replacement warranty, limited lifetime warranty
    - Stronger and more flexible
    - Stainless steel finish looks great and will last
    - No need for oem clips with easy to install threaded cable mounting ends
    - Includes Billet Shifter Cable Trans Bracket as a package
    - Low friction teflon coated inner liner, stainless steel inner cable
    - Heat resistant polyethylene outer covering
    CorSport USA.
  6. CorSport
    CorSport Member
    Honda/Acura K20 K-Tuned Billet Oil Dipstick
    [​IMG][​IMG][​IMG]
    Applications: Fits all 2002-2013 K-Series engines.
    The current trend in Honda builds seems to be somewhat focussed on clean details in the engine bay. With that said, we think most K owners would agree that the OEM orange dipstick on the K engine looks completely out of place, especially on a custom valvecover in a super clean engine bay. The JDM black dipstick is a slight improvement, but the height still has some fitment problems on some chassis. After seeing these unfinished looking dipsticks way too often, we decided it was time to offer something on a higher level to our customers.
    The K-Tuned Billet Oil Dipstick was designed to follow the exact contour of the OEM valvecover, giving it a smooth, shaved *look. Along the bottom of front edge is a small flare, which is just enough for removal. Look closer and you'll notice a small hole located at the center of the flared front edge. This can be used to attach a spring tie down on boosted applications where increased crankcase pressures can blow out the dipstick.
    Starting with the 6061 billet aluminum top, our signature K logo is engraved after anodizing. All the remaining parts are 100% stainless steel, including the base, wire and level indicator. The base seals properly with 2 o-rings just like OEM and the level indicator has 2 markings on it, again matching OEM. Available for both K20 and K24 engines in 5 colors plus raw aluminum for those who might be interested in polishing or a custom color match.*
    CorSport USA.
  7. CorSport
    CorSport Member
