osideracing760
hey guys.Doin a k20(full swap) on my 95eg,off a civic si 04.got everything done.jus a few minor details left.I'm using the stock ecu. wit wire harness(idk) got it from craigslist,almost all done(wires).don't have money 2 k-pro yet.what immobilizer do i need just to get it running? Im also using a tsx header.tried to customized the stock headers but it broked.. custome made the fuel rail,jus put a valve n connect to fuel line for return, made a mount/bracket for the radiator to switch side.so I need the type of immobilizer and also do I need the shift gear mount? took off the power steering and ac, but what do I do with the ac pump? any help to get it to run will b appreciated. i need this car to run.
